How to define the id of a widget on the designer so additional software can access it
Need Answer Avishay 3 years ago
Trying to find a way to use the created HTML inside a much larger Angular project.
The widgets should be identified by code using the id attribute
Is there a way to control the value of the id attribute?
Unfortunately it is not possible to use the html in that way, the tool is designed to create prototypes, as for the way to control the value of the attribute id, you can always download the html and manually edit them.
I hope this information is useful for you.
Thanks for a speedy reply.
