Need to Export Comments to file
Under Consideration Cameron Gull 3 years ago
I need the ability to export comments as a file. I know you can export them to a Word Spec Document; however, I just need to export them to a CSV - similar to how you can with Requirements.
Hi Cameron, in order to export the comments, you need to download a plugin that you can find at the bottom of the following page: https://www.justinmind.com/prototyping-tool/api-sdk
the plugin is called:
Export comments to CSV
To install it you just have to click on 'Download', open Justinmind, go to 'Plug ins' in the menu and select' Install plugin;
Once that is done, in the 'plug ins' menu you will have the option to export comments to CSV.
I hope this information is useful for you.
Gtts.
Ria.
