Upvote 4
Add ways to organise the list under the "Masters" panel.
Like the screens panel the masters panel can get quite busy. Being able to categorise masters with folders and moving them around would be helpful. They currently list by date added?!
Failing that even sorting by... ascending / descending would help.
Hi Brad,
Thank you for the suggestions!
This features are already on our product's backlog. We will tell you when an update
includes that function.
Sonia
I see that this idea had been added 2 years ago, but it's still "under consideration", so I'll add my 5 cents to the discussion.
Masters are a great feature, but lack of an ability to organize them can turn out as a real bottleneck for big projects. Usage of masters allows starting work quickly, without thinking of a final design for each common element; just adding such groups as e.g. input-icon-caption to masters allows refactoring them in one place without running through the whole project page by page.
Such a workflow requires at least tens (may turn to hundreds easily) of masters. In the current application state these masters are being sorted on the panel, sic - by creation time. Not even by alphabet, so I'll be able to find the one I need in two or more weeks; it's just not usable with more than 20 masters.
IMHO the same goes for Variables tab, as making something smarter than a homepage may require quite much of them. By the way, are there any limitations on numbers of masters and variables used in the project?
Thanks for your detail in describing the problem! I have let our team know that more users would like this feature.
Also, there are no limits for the number of masters or variables in a prototype.
Thanks. BTW, my bad - after program restart masters been sorted alphabetically (at least). I'll be so glad too see it implemented.
2 years ago, no update?
Unfortunately not. I will add your wish to this feature so our development team can take it into account.
Thank you for the reply Sonia.
