how to edit pie charts
Known Nicole Birdsall 2 years ago
hi, I am trying to customize the pie chart from the charts UI widget. I want to change the country labels to a legend instead and only have the number with the arrow instead of the country label AND number with the arrow. how can I do this?
Hello, you can use the direct selection from the toolbar (A)
to select the name you want to change, once selected double click and you can edit.
from the layer you can also select the text and change it from the canvas.
let me know how it went.
I'm trying to convert the labels on the pie chart to a legend, since the pie chart template already comes with labels. Is there a way I can do this without having to delete and change every single label individually and manually create the legend?
hello, you have a chart with legends in the widgets (attached image) and there is no automatic way to edit it, the widget is a set of elements, you have to edit the legend manually.
