Screen Watcher | Real Time Server
Under Consideration Petatemarvin26 2 years ago
Much better to, whenevery we run the app there is watcher for changes :)
Hello, could you give me more information about your query.
Like a live server, when every save on file `myfolder/index.vp`, the system watch that file, if the file change the server also refresh and fetch the file like what the system doing evertime we hit the button "run"
it is pretty convenient compare to, run and run so manytimes and create new tab just for a lilttle changes
Hello, thank you for your suggestion, we will take it into consideration.
Welcome, you may update us because currently we are using your platform, it is pretty convenient and efficient also userfriendly compare to other wireframing & designing software,
petatemarvin26@gmail.com
here is my email, I will update also my team if you've release a new patch for that suggestion, Thank you,
regards
Hi, thanks again, we'll keep you updated.
