Can't find the index component in version 9.9.0
Known Gamado 2 years ago
I'm trying to set up pagination on a datalist. In previous versions I was able to use the index component to navigate through a multi-page datalist. The index component no longer appears with the datalist and datagrid components. Has it been moved elsewhere or is it no longer supported?
Thank you.
Grace Amado
Hello, sorry for the inconvenience, the index component is not available.
Has the index component been removed completely? I've come to rely on using the index to allow me to paginate my data lists. It would be a shamed if it were no longer part of the product.
Grace Amado
Hello, I'm sorry for the inconvenience, remember that the components can be created manually, I leave you an index that you could perhaps use.
Thank you for the work around for the index component...this is helpful. I hope that in future versions of the product you might consider including the index component again.
Cheers.
Grace
Hello, you're welcome, we will take your suggestion into consideration.
