Variable Additions Not Showing On Output Panel
Known 47salazar 2 years ago
I created a screen with a dynamic panel that contains a couple of panels. I used a data list that is pretty simple and contains three fields: photo, name, username. I then overlayed a button on top of the image so that a user can click on and on a second panel show the selection chosen. I am so close but I can seem to get the variable output to show in the second panel. I attached the file that I am using. I tried adding a an event to the second panel, page load + set value to variable but that does not work.
Hello, I am attaching the example where you can see a "On variable Change" event in the Dynamic Panel in which each time the variable that contains the name of the user who has clicked, it shows the information of the user in the second panel.
Let me know if the information is useful.
Thanks Ria, this is exactly what I was looking for. I appreciate it.
You're welcome, let us know if we can help you with anything else.
