Not able to access my project after upgrade SB217457
Known Martin Elwenn 2 years ago
Hey Ria,
thanks for your reply.
After relog I have the same issue. All I see is the loading screen showing the bird on the right and then upgrade pop up appears.
I am not even "allowd to see this page" trying to answer your question by clicking the "open comment on browser"_button (you asked me to relog and see what happens).
What can I do to access my project.
Thank you and regards
Martin
Replies (11)
Hello, sorry for the inconvenience, have you tried?
"You can also "use the free edition", and look at the email with which you are logged in, with the toolbar icon, just to verify that your projects are not in another account."
Let me know.
Hello, yes I tried this too and it returns some message regarding activation error...:
4c7ce30d543f18966fca8d6888951677
Hello, are you using any proxy?
Yes, proxy & VPN-tunnel in case I work from home.
Regards
In case you're going to ask me to tlk to my Admin, pls let me know
a) what exactly we have to allow?
b) why this didn't come up during the free edition phase?
Hello, the connectivity is with
https://cloud.justinmind.com/ through port 443
Could you send us the logs?
Hello there,
pls find the logs attached.
Thanks, best.
Martin
Hello, I'm sorry for the inconvenience, we were not able to identify the error so it must be a connection problem: I send you to the configuration: url https://cloud.justinmind.com/usernote :: 443
you also have to enable the firewall
Greetings..
uhm - I think I found it. At least I found something that went wrong, pls. see log:
****************** log *******************
[2224] [2023-02-03 15:25:24] WARN com.justinmind.prototyper - Unable to send error report org.apache.http.conn.ConnectTimeoutException: Connect to cloud.justinmind.com:443 [cloud.justinmind.com/52.0.113.134] failed: connect timed out
at org.apache.http.impl.conn.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:143)
at org.apache.http.impl.conn.BasicHttpClientConnectionManager.connect(BasicHttpClientConnectionManager.java:338)
at org.apache.http.impl.execchain.MainClientExec.establishRoute(MainClientExec.java:380)
at org.apache.http.impl.execchain.MainClientExec.execute(MainClientExec.java:236)
at org.apache.http.impl.execchain.ProtocolExec.execute(ProtocolExec.java:184)
at org.apache.http.impl.execchain.RetryExec.execute(RetryExec.java:88)
at org.apache.http.impl.execchain.RedirectExec.execute(RedirectExec.java:110)
at org.apache.http.impl.client.InternalHttpClient.doExecute(InternalHttpClient.java:184)
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:82)
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:107)
at com.justinmind.usernoteclient.ui.a(ui.java:488)
at com.justinmind.usernoteclient.ui.a(ui.java:471)
at com.justinmind.reporter.hv$wi.a(hv$wi.java:39)
at com.justinmind.reporter.hv$wi.call(hv$wi.java:1)
at javafx.graphics/javafx.concurrent.Task$TaskCallable.call(Task.java:1425)
at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
at java.base/java.lang.Thread.run(Thread.java:834)
Caused by: java.net.SocketTimeoutException: connect timed out
at java.base/java.net.PlainSocketImpl.waitForConnect(Native Method)
at java.base/java.net.PlainSocketImpl.socketConnect(PlainSocketImpl.java:107)
at java.base/java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:399)
at java.base/java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:242)
at java.base/java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:224)
at java.base/java.net.SocksSocketImpl.connect(SocksSocketImpl.java:403)
at java.base/java.net.Socket.connect(Socket.java:591)
at org.apache.http.conn.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:337)
at org.apache.http.impl.conn.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:134)
... 16 more
Does that mean something produces a web socket error maybe? (wich would foster your assumption it's a connection error)
However I don't know
a) where to get the "host" from that you request in in your configuration popup:
b) how "enable the firewall" as you suggest
Thanks for your help
Best
Martin
5270682e8e805b50cacae96b7a8ff957
Hello, it seems that you have misconfigured the proxy options in justinmind.
In justinmind proxy settings, you need to fill in the URL and port of your proxy server and in authentication, the authentication user and password of your proxy server, if applicable.
The url and port we provided is to open that url and port on your proxy server, not justinmind's configuration.
