White flashes between parallax transition
Known Albuenaerl711 2 years ago
When using the fade parallax component and initiating a transition, there is always a brief flash that occurs.
Hello, would it be possible for you to send us your project to review it?
Thank you.
Here the file I hope you can help with this.
Hello, could you tell us the operating system of your computer and what browser you are using?
Hello! The Problem has been fix you only need to put a rectangle under the fade parallax to prevent white flashing.
