How to link a data grid to other screen dynamic panel?
Need Answer Albuenaerl711 23 months ago
Hello.
I want to know if you u can link a data grid to other screen's dynamic panel. If i want to select button 1 on the data grid it will go to the other screen dynamic panel's panel, then if i want to press button 2 in the data grid it will go to the other screen dynamic panel's panel 2. Hope that this will be answered.
Hello, you can add the images from the data master, in a data grid, save the value of the image in a variable and in screen number 2, you can do a "Set value to an element" to an image container, equal to the value of your variable.
https://www.justinmind.com/support/variables/
Hello, I successfully link the data grid to the dynamic panel and I follow the example you give but it only show the default panel in the 2 screen.
Here is a video to show the problem
Hello, you can use a "set active panel" event to show the panel you want, if this answer is not useful to you, could you tell us in more detail the result you are trying to achieve?
Thank you..
