Datagrid settings
Known Kenyipkw 2 years ago
Dear JIM Support,
Could I do the following settings in datagrid
1) Set one boolean column data to be editable
2) Change color of row of data >= 30 blue and >= 120 red
3) Press each column header and then can be sortable for that column
Thanks,
Ken
Hello, I leave you more information on how to use the sort function, you can also find how to make an editable column here:
https://www.justinmind.com/support/how-to-sort-data-list
Regarding the color, you can edit the color from the properties, but if you want to edit depending on the condition of a row, I am attaching an example, if you select the current row you will be able to see the event that conditions the color change.
Thank you Ria !
You're welcome, let us know if we can help you with anything else.
