Modification of text table in Masters are not reflected in screens
Known Jonathan Serex 23 months ago
I created a Master with a text table inside of it. The master has been positioned on several screens.
The issue is: When I modify the content of the text table in my master, this change is not reflected in the screens where the master is positioned. In order to see the modifications, I have to delete the master in each screen and re-include it. See also the attached video as an illustration of this issue.
Thanks in advance for your support on this issue.
Kind regards,
Jonathan
Hello, in order to help you better, could you send us your vp?
Could you tell us if the same happens if you create a new Master or it only happens with this particular Master?
Thank you.
Here is the vp file.
Regarding your question, I could not reproduce the issue by creating a new master.
Hello, we appreciate the bug report, we are working to solve it in a future version.
