How do I go about selecting the last record added to a Data Master?
Need Answer Marksmithhart 23 months ago
I have a page where I can add a new record to a Data Master. My "Submit Record" button then navigates to a "Record Successfully Added" confirmation page.
I would like to display some of the newly added record data on this page. What is the easiest way to pull data from the last record to be added to the Data Master?
Hello, you can create a variable that contains the information of the record that you want to show and reflect it in a new element on the new screen. I leave you more information on variables: https://www.justinmind.com/support/variables/
Let me know if this is what you need.
Ok, that's the way I ended up doing it. I was just curious if there was a way to access the last record added to a Data Master without using a variable. Good to know. Thanks for your reply, Ria.
Hi, you're welcome, if you're changing pages, it's the best option, if you're on the same page, you can use panels and set value too.
