Exporting screens using Data Masters to image files
Need Answer Michal Kloczko 20 months ago
Hi! Is there a way to export a screen that uses e.g. a Data list and have the actual data (defined by the related Data Master) rendered on the image?
My experience is that Data Masters entries are rendered only in the simulation mode, is this the intended behaviour?
Hello, it is possible to download the information from the data master to a csv file or a canvas to an image but you will not be able to see the records. You can capture the image from the simulation.
Thank you, Ria, cheers.
