Uninstall in unattended mode
Known Tmaria 18 months ago
We have Justinmind ver 9.5.3 installed on several lab computers. Can I uninstall it in unattended/silent mode? Running uninstall -q does not run in silent mode.
Also how can I install Justinmind free latest version in silent/unattended mode?
Thank you in advance
Maria
Hello, To uninstall Justinmind in silent mode, you can use the command-line option /S or /VERYSILENT. If you encounter any issues or need further assistance, please provide more details about your specific setup and the operating system you are using.
Hello Ria
we run windows 10 ver 21H2. I tried from the cmd (also as administrator) from C:\Program Files\Justinmind\Justinmind 9.5.3>uninstall.exe /s and also tried C:\Program Files\Justinmind\Justinmind 9.5.3>uninstall.exe /verysilent but on both cases a pop-up is up asking if I want to remove Justinmind and its component
I want to remove justinmind ver.9.5.3 without any user intervention
Thank you
Maria
Hello, we are sorry for the inconvenience, Justinmind version 9.5.3 cannot be uninstalled using unattended mode due to a bug with that particular version. However, you can install the latest version of Justinmind in unattended mode (-q) without any problems. We recommend downloading and installing the latest version to ensure a smooth installation process: https://www.justinmind.com/download
Hello Ria,
Many thanks for your reply. Can I have both versions installed on the pcs. Since we can not uninstall easily ver9.5.3 , can I install and run the JIM latest version without any consequences?
Thank you
Maria
Hello, yes, you can have both versions installed.
let us know if you need further assistance.
