Master or Custom Widget
Need Answer Mary 14 months ago
I would like to build a series of list widgets using different data configurations from my data master. My question is this, is it better to build Masters or add Components to my Custom Library? The choice may be obvious but I'm a newb...
Hello, both options have their advantages and it ultimately depends on your specific needs. If you anticipate reusing the same list widget with different data configurations within a single project, building a Master can be beneficial. On the other hand, if you want to create a custom list widget design that you can reuse across multiple projects, adding it to your Custom Library can be a good choice.
Please let me know if there's anything else I can assist you with.
Thank you Ria, for clarifying the use cases. Much appreciated.
You are welcome! Let us know if we can help you with anything else.
