Select List and Data Master
Known Mingorance33 11 months ago
I have a Select list populated with a Data Master (Data list). This Data master have two columns. I need in the Select List select only the first column.
You can prototype it using a setValue triggered 'onPageLoad'. The value should be an expression that 'selects' the desired column from your data master (as shown on the attached screenshot).
I'm attaching a simple example to demonstrate it.
Best regards
