Moving a picture along with the slide bar button
Known s.ludwiczek 23 months ago
We are currently trying to desing some apps about soil and have experienced some trouble with executing our ideas. Is it possible to fix a picture to the button of the slide bar, so that the picture moves along with the button and that the picture then changes if the button/picture reaches a certain position?
Find attached an example of what you ask. The tennis ball image over the slider will change from the default image to the reversed one when the slide reaches the second half of the slider and will change back when the slide is less than half again.
Hope that this fixes your problem.
Best regards.
Thanks a lot. Exactly what I wanted!
