A white background appears between the transition effects.
Hi ~
I use the "JUSTINMIND" trial version.
I learned a lot by studying the tutorial.
But there is one problem.
When simulating a transition effect on the screen, a white screen appears between the transition effects.
Are there any transitions while maintaining the previous screen?
We found the same issue in the community, but we could not fix it.
Of course, there are alternatives to using dynamic panels.
However, a screen transition is required to show scenarios on a completely different screen.
Please check the motion picture of attached file.
I hope I have a solution.
The operating environment is Windows7.
The simulation is for Android Phone.
This issue can be a major constraint on your purchase decision.
Please check the attached file.
Thank you for reporting this. Unfortunately it looks like the file wasn't attached. You can try uploading it to a file sharing service, such as Dropbox, and link to the file here.
i have a similar problem. i not stay in office until next week. i can't send you the vp file.
but you can reproduce it very easy. just make a prototype with 2 pages. add black backgrounds to each page and link one with the other. if you simulate it on android or ios you will see an annoying white flash while it switchs from one screen to the other. even on a very fast device you see the white flash very good.
please fix that or tell me how to fix that. we have a lot of customers which really don't like that.
thanx
thanx
