Upvote 8
Add a "Disabled" state for buttons or even for every widget
Completed Victor Conesa 11 years ago
Every component could have the checkbox "simulate disabled state" near "hide component".
If this checkbox is checked it will become 50% transparent and all the events on in should not be active.
Then I would like to have an event that can change this state. For example: on click "enable" button1.
Replies (4)
At least buttons could have such parameter, similarly to checkbox.
Currently it's excessive work to cover the button with semi-transparent recntagle and hide it by events.
This is a good idea.
Currently it is necessary to both change the component style manually and disable the events inside that component. This way the necessary logic is complex and has to be put and maintained in two different places.
This needs to be done for checkboxes as well as other appropriate controls. This is a must have!
Would like the behavior as well. Useful for form Save buttons that need to be in a disabled state until the requisite fields are filled out.
