Adding a column of data in data master
Solved GUO LINGXING 5 years ago
Hi I'm new to JustInMind,
Currently i wish to add a column of data to a text. From the research I have gathered so far, I know that i should create an add event to the text, on page load, add calculate expression and use both sum (filter(datamaster, attributeName)). However, the text is not showing anything.
Please advise! Thank You.
You won't need to use the Filter function. You'll only need to use Sum (Data master, attribute). Check out the attached prototype.
OH MY, THANK YOU SO MUCH
Glad to help!
