Bug (?): Blinking panel
I programmed the following interaction: hide panel 1 and then show panel 2 when input text is on focus. It does work, however, everytime I click on the input again, panel 1 keeps blinking. I assume Justinmind behaves like that because it understands it's not possibile to hide an element which is already hidden, so it shows up again. :P Sounds like a bug, doesn't it?
Hello Camila,
Thank you for reporting this behavior. We'd like to investigate this a bit further and would be grateful if you could provide the following:
1. Full system specifications
2. Justinmind version bering used
3. Detailed description of all steps leading to this occurrence
Luisa
Hi Luisa,
I use a Macbook Pro (Yosemite 10.10.2) running the version 6.4.1 of Justinmind.
Is there anyway I can send you the .vp?
Tks
