Upvote 4
Can I change the height of the select list?
In our pattern library, all of our input patterns have a height of 40px for touch capabilities. Is there a way to change the height of a select list to 40px?
When I brought one into my workspace, the height was deactivated (so I'm guessing no but thought I'd ask just in case). Thanks.
Replies (5)
I also need to change the text size within the select list too. It looks like it defaults to something small (11px maybe?). I need it to be 16px.
Hi Amlynn,
You will be able to do that by using the "custom select list" widget and adapting the height on the properties tab,
Perfect! Thank you! I didn't realize there were two separate drop lists and only one could be customized. I'm a bit new to the software, can you tell?
No worries. We are here to help.
The height and width in the properties tab are not accessible, they are greyed out. How do I change these values? I have a paid subscription.
Perhaps it is because I'm working on an app and they can't be adjusted or they will be too small to be legible?
You won't be able to adjust the size of a select list. Try using a Custom Select List widget instead - you'll be able to customize that.
