can u explain me step by step hide / show animation in justinmind?
RESOURCES
Copyright © 2025 Justinmind
Footer policies
Footer policies
Footer policies
Hi
1. Add to the canvas one label and one button.
2. Select the button and go to "Events". Now, select "add event".
3. Select Show/hide action, then click into the hide radio button and select the label.
4. Click "OK" button.
Now, to show again the label, you have to proceed exactly as the hiding option, but selecting the show radio button instead of the hide button.
That's all. To check it, click on simulate.
Hi
thank u... i need another help from u. how to do timing of hide / show interaction as well as looping the images?
When you select the type of effect, you can change the timing of the interaction.
For now, the only way to do a looping is copying and pasting the actions a lot of times.
Thank you albert its really helpful for me..
Looping Solved - I think ...
Here's my loop scenario - screen has a set of circles that need to flash (like an alert). I tried the hide-pause-show-pause-reload trick but it seemed very bad. I also want to play an alarm beeping sound and dont want it to play over and over - so linking to same screen again wasn't a way for me.
Alright, I broke my head over this and solved it this way -
I added two input fields, made them completely transparent (no lines etc). Upon page load, I set focus on first text field. In the On-Focus-In event of textfield1, i hide the circles, pause and set focus on textfield2. In the On-Focus-In event of textfield2, I show the circles , pause and set focus on textfield1. And now I have a loop and my flashing circles forever without reloading the screen ! :)
Hi, How to hide multiple labels when selecting dropdown value?
Ex : In dropdown list, 3 values will be their : 1) Product 2) Brand 3) Basket
If I select product, Product label should be display, rest two labels it should be hided.
Thanks for your reply
Hi Praveen,
Please check this simple example I've created for you. I hope it helps.
https://www.dropbox.com/s/jp6405fqnrm...
Hi Praveen,
