Cannot set active panel for a second time in simulation
Answered Katie 8 years ago
I've built an amazingly complex e-form with this tool which is awesome, so thank you!
I just have one level of functionality that I can't work out. I've attached a file to show you the details.
If you check 1, a panel shows up. If you close the panel and check 3 a different panel shows up.
However if you check 1, the panel shows up and you click "Add referral" then the other panel will not show up when I check 3. And vice versa.
What do I need to change to make this function properly?
Thanks in advance for a quick response :)
Replies (4)
Hi Katie,
Change the 'on tap' event to 'on toggle' and the event will work.
Hi Danielle,
Thanks for getting back to me. I've tried what you've suggested and it works in the same way as the last version I uploaded - it works fine for the first time you click on it, but then doesn't show the second one if the first one has already been shown and hidden again.
Hi Katie,
So sorry for the delay in getting back to you! Here's a fixed version of your prototype with the correct events. (https://www.dropbox.com/s/92mla2iugi5otb3/Prototype%205%20problem_FIXED.vp?dl=0)
Thanks very much! This has fixed it.
