Can't add images from outline to datamaster. Can't modify only specific datamaster fields.
Justinmind does not seem to be able to do the following:
- Modify specific fields of a datamaster row (without affecting the rest of the fields)
- Take a image as a value from the outline, when modifying or adding a new row into a datamaster.
With this two limitations and when the datamaster contains images (often), its like not having the new and modify functions at all. Every time I modify a item of my datamaster I will break it removing its images.
Any solution for this?
fb90a6762a7841bf1fea057b9aa4a785
Replies (6)
Hi Diego Pau,
Yes you are right. We've detected a bug and unfortunately there isn't any workaround to it. Our development team has been informed about it and we will let you know as soon as it has been fixed.
Sorry for any inconveniece.
Thanks a lot for the feedback Sonia!
Hi Diego,
I'm happy to inform you that this bug has already been fixed and it will be available on our next release.
Awesome! thanks a lot Sonia.
Hi Diego Pau,
I'd like to remind you that this bug has already been fixed and it has been implemented on our last 7.1.0 version.
nice!
