Upvote 3
Can't copy paste anything
Solved Danielvanderpluijm2011 4 years ago
I'm not able to copy paste any objects ( in general use CTR +c) since the last update. It says unexpected error. How can I get the old version?
Replies (4)
Thank you for reaching out. Could you please attach your log files so we may take a look?
As I'm facing the same issue (Do you test your stuff? - It's the copy function!) could you please give us an old version?? I can't work with the tool right now.
Even the logs.log.1 could not uploaded without renaminng.
I've to add that I could also not create any event and getting an unexpected Error too.
I deleted the current version and installed everything from scratch. It works now.
Did you uninstall the current version and reinstall it?
Hi, yes I uninstalled the latest update (a day before) without deleting my own data.
Thank you for this information. Which version of Justinmind are you now currently using?
Hi, current version number is 9.1.12
