can't hide table row
Solved Victor Conesa ● 13 years ago
I added a click event to a button and selected a table row to hide, but a error shows up saying that the item selected is not valid.
Can I not hide table rows?
Here's an example. It resizes a column to be 0, so it's effectively hidden. The other columns will move to fill the space where the column has been hidden.
What kind of table are you using? A text table, a data grid or a table?
Same problem for me, using a Data List.
You won't be able to add a 'hide' event to an individual row in a data list, you'll only be able to hide the entire data list.
Well, you can actually hide a row by setting the height of the current row to zero. You need to base such height action on a variable set in the data master for the individual dataset. Otherwise all the data rows will be 'invisible'. Kent
Hi Kms,
I need to be able to hide a column using the same logic of setting the width of a current column to zero. I presume that setting a column width to zero doesn't leave a gap in the table but allows the remaining columns to fill in the space. Is there a working example of how to implement the width or height action on a variable set in the data master?
Thanks so much Danielle!
