Copy and paste Master object removes events
I have a header and footer master, with events created for everything within. I understand I can place the master element into the new screen, but there are other elements I want to copy and paste just for that one page. So, instead of placing the master elements, I SELECT ALL *which highlights both the master elements and everything else*, COPY, and PASTE into the new screen.
However, now, ALL events for ALL master objects disappear. Any events within non-master elements are retained. If I hit undo, it does not bring the events back into the master. I have to redo every link. It's quite frustrating. Perhaps a bug?
Since I cannot undo the change I have been forced to redo the events for all the links within master elements a few times, until I realized it wasn't something I was doing. My process may not be proper, but I don't believe a copy/paste should removed master events/links.
Dave
Hi David,
Thanks for letting us know about this. Unfortunately I was unable to reproduce this using the steps you described. If possible, could you take a screen recording of this so we can see the error?
Hi David,
