Creating elements in table cells
Known Todd Pierpoint 4 years ago
I've created a table and would like to add elements in the cells. It seems when I add an element it doesn't become part of that cell. This seems like a fairly fundamental issue. Surely there is a way to do this. Would someone please point me in the right direction? Thank you
When putting elements into a table, make sure that the element is in the correct cell. You can check this by going to the Layers palette and making sure that your element is under the correct cell by dragging and dropping the element over the cell you want it in. Let me know if this helps answer your question.
