Upvote 3
Data Master Field Types
Solved Jeff 8 years ago
When creating a field in a Data Master I want to set it up as a category with a drop down. When I drag it out for a from this is great as it is a drop down/select which I want. However, when I add a Data List table for the view, the field shows up in the table as a drop down/select, which I don't want. When viewing all the records, all data should just be plain text fields. Is there a way to do this?
How was this solved?
We're not sure why this was marked 'solved', but here's how to do this:
a88d6c4bd630ddcf84af42c1e8bfea9b
Then go to view and edit the records of the data master and select a value for each record from the dropdowns.
