Upvote 3
DataMaster is not showing Images uploaded by File Upload Input
Known jolly thakkar ● 9 years ago
I have One field of Image in my data master. I have set it's field value to File Upload.But when i browse any image..it's not showing actual Image instead of image it's showing some text !!..
I don't know whether the problem is in image format or what?
Dear Jolly,
Unfortunately, I can't reproduce your issue. If possible, can you create a video capture so I can see what might be happening?
PFA for sample demo application.
In this demo, I have added below details.
1. Insert Item Id and item Name
2. Browse an Image
3. AddItem Button
I need to fill DataList control when user clicks on AddItem with all information filled including image.
I am able to fill Item Id and Item Name in DataList control but not the image. So can you please suggest to fix the issue ?
Dear Jolly,
You may recreate a browsing action by using JustInMind's 'File Upload' widget. However, you will not be able to set the file path chosen to the DataList, as this is simply meant for a 'browser' simulation.
