Design a menu bar
Solved Pratyush 8 years ago
Hi
I want to design a menu bar which has links to various other pages in the module. And I want the exact same bar to be on many other pages(Screens ). So, what I want is that if I modify the bar at one place, the changes should be reflected everywhere else (i.e it behaves like an API ). Can someone please suggest a way to do this?
Thanks for your help
It sounds like a Master will be helpful for you. Masters allow you to create one reusable element or design, apply it to different pages, and update all pages with any changes you've made to the master itself. Check out more information on masters here: https://www.justinmind.com/support/how-to-apply-global-changes-to-your-interactive-prototypes-with-masters/
