Developer users should see the event panel.
Under Consideration ssongporn ● 8 years ago
I got the problem when we add hover effect. They cannot pick the style of button while being hovered.
Developers can't see the events panel. I'll let our team know that this feature is requested.
As a workaround, a developer can generate a document (File -> export to document) and that will contain all events in the prototype.
I am unable to see the events Palette, and using the CTRL_SHIFT_E combination to trigger a new event on a button is not working, the view Events Palette is enabled, what is the problem here??????
Can you try going to View -> Reset workspace?
