Do you create different prototypes for each platform (Android, iOS)?
Solved Sergej Filippov 7 years ago
What is the common practice when you asked to prototype for Android and iOS?
Hi Sergej,
You have two options:
-If you are going to use all the native widgets of each platform you will have to design two different prototypes.
-In case you are using customized widgets then you will be able to use the same and simulate in both devices by changing the device at "Simulation Settings" (Click on the gear next to the "Simulate" button).
