Dynamic Panel does not take hundred percent width inside a panel
Solved Sheraz 6 years ago
Context
I have placed three dynamic panels inside a parent dynamic panel. The three child dynamic panels have width set to 100% width.
Problem
The three panels inside the parent dynamic panel will only take the full 100% width when I have applied a vertical layout on the parent dynamic panel. If no layout is applied, the panels inside never take the full 100% width which is causing lots of problems.
I have to stick one of the panels inside to stick to bottom which can only be done if I remove the vertical layout but then panels don't take 100% width.
Google drive link which has screen recording and prototype for reference
https://drive.google.com/open?id=1BoRXM5iWWDu7PFItyd-W0p4HWd8R3pZy
Looks like there is a bug here! We're going to fix this soon. I'll let you know when we have an update. As a workaround for now, you can turn the horizontal layout of Dynamic_Panel_6->Panel_6 into a Free layout
Thanks !!! This weird workaround actually worked for me :)
Waiting for the fix.
This has been fixed in our latest update (8.7) that was released yesterday. Go to Help -> Check for updates in Justinmind.
