Dynamic panels back button
Solved Thomas Barton 6 years ago
I have an issue where I am using dynamic panels but need to go to the previous panel when the user presses the back button. Since there are multiple ways in which a user can arrive at the active panel in question, I can't just statically take them back to a particular panel when they press the back button - I need to take them back to the previous panel they were on. Dynamic panels are very powerful, but without a "go to previous panel" option they are quite useless to me. Any ideas on how this functionality can be accomplished? Thanks in advance!
While there's no default 'back' dynamic panel button functionality, we can create a workaround using variables and 'on panel active' events.
On each panel, we create an "On Panel Active" + "Set Value" event, setting the value of a variable to 1, 2, or 3 (depending on which panel it is. For example, Panel 1 would set the variable to 1, Panel 2 would set the variable to 2, and so on). We'll use this to detect which panel you were last on before you click to Panel 4 (the panel with the 'back' button).
Then, for the 'back' button on Panel 4 we've created "On Click" + "Set Active Panel" events that set each panel as active. So, if we have 3 panels, we have 3 "On Click " + "Set Active Panel" events. Then, we've created a condition for each that is When... Variable = 1 (or 2 or 3 to correspond with the panel we've set as active for that event).
See the attached prototype for an example, and let me know if you have any questions.
Danielle - thank you very much. This is great. I had not thought to use variables and conditions to achieve this functionality. You have greatly expanded my proficiency with JIM and I appreciate it very much!
Glad to help!
