Easing STYLE CHANGES (Not possible)
Solved Jseabright 5 years ago
Hi. I am trying to change the opacity of some text as it moves down (by20px) from 0% transparency to 100% transparency. It works but it animates this transition INSTANTLY, however I'd like it to gradually reduce the transparency as it moves. I don't think this is possible as all STYLE CHANGES happen instantly. Is this correct.
Just worked out the answer to my own query. Instead of creating a STYLE CHANGE interaction, I have created a HIDE/SHOW interaction, and then set the text to FADE, this then gives me the option for easing, and I can set the interaction to run WITH PREVIOUS, so that it happens at the same time as my MOVE interaction.
