Upvote 3
Expor project to apk ?
Once finished , you can export the project apk format
Unfortunately this isn't possible.
Justinmind provides several options to get you on your way to creating a real, working application from your prototype.
Option 1: Use the API/SDK to generate some interface code. Learn about this here.
Option 2: Export your prototype to HTML (File -> Export to HTML), which will generate a document with folders including HTML, javascript, and CSS.
Option 3: Use Developer Mode. Your developer can check out the CSS and other assets within the prototype.
