Export to HTML - Does not work with IE 11.0
Solved Robert Grashuis 8 years ago
When exporting to HTML in 7.4 or 7.7, the HTML does not work (display properly) in IE 11.0.
It displays both the content of the page + the code on screen.
Is there a fix for this problem?
Hi Robert,
Thank you for reporting this. Is it possible for you to include a screenshot of the correct simulated version vs. the incorrect exported version?
We are currently looking into this, but as a workaround for right now, you can change your simulated browser by opening Justinmind, then going to Preferences - Default browser -> select another browser application.
Hi Danielle,
Thanks so much for your quick reply. I've since learned from Victor the issue is the security restrictions within IE 11.0. There is currently no way to run an exported "stand alone" HTML version of a simulation in IE 11.0. You have to use another browser or a different version of IE for it to work.
Kind regards,
Robert
Hi Robert,
Thanks for the update. Were you able to correctly use another browser to simulate?
