Exporting to HTML
I want to export my prototype to HTML so my UI developer can look at the HTML, CSS, JAVASCRIPT code.
When I use the File > Export to HTML feature, I get too many directories and the exported code is not formatted; it is all run together.
I am evaluating this software and if we are stuck with this type of export, then this probably will not work for us.
To export to HTML, go to File -> Export to HTML.
If you would like an export with only the essentials, go to Preferences and uncheck 'Optimized', and then export to HTML again.
The folder generated by exporting to HTML will contain an index.html file that you can use to view the simulated version of your prototype.
You can click on Resources, then screens, and then you'll see the CSS and Javascript.
Select the option File -> Preferences in your Prototyper and uncheck the option 'Optimized'. Then export your prototype to HTML again.
