Generating empty word-documents when exporting specification document (both customized and not)
Solved Mel 5 years ago
Neither way of generating a specification document works [File>Exporting>Spec/Custom Spec Doc]
Both using a customized template and using the pre-defined document of JIM 9.1 produce an empty word document.
I wanted to finally test the new feature of exporting custom requirements, but I didn't even get so far.
Thanks in advance
Melanie
Hi Melanie,
Sorry for the delay on this response. Could you attach your prototype and log files so then we can take a look? You can compress it to .zip/.rar and attach it here.
You can find the log files by following this file path:
I look forward to your response,
Attached the files
The issue you were experiencing has been fixed in today's update. However if you created a custom requirement field that has a space, in the MS Word template the tag for that must be without spaces.
Please let me know if you have any other questions.
