Getting dimensions and position of widget or button or text
In Progress Helly Shah 6 years ago
Can we get position,colour size from screenshot captured if the screen created in JIM .We want a way ot that one can get dimension and position of buttons,widget etc from screenshot.Is there a way for that.Do we have any document created which can show all these data for each screen.
Kindly help out with this as soon as possible.
Thanking you
You cannot get this data from a screenshot of a screen in Justinmind. However, if you select an element in the Justinmind application and then look to the CSS palette, you will see its dimension, color etc.
Alternatively, you can export a prototype to HTML and then navigate to the folder it generates. You can then see a file that lists the properties of the widgets in your prototype.
