has anyone figured out how to re-order columns in a table?
So I'm usig datamaster and datalist to generate a table, once I create the table, I can't really make new adjustment. For instance, I try to update datamaster with a new column but I notice, the change is not reflected in my table. So I created the new column in my table manually. The new column shows up as the last column in the table, but I need to display the column in the middle of the table.
Is there an easy way to do so?
found the answer
The order of the Data Grid's columns can be modified once created. To move a column to a different position within the Data Grid, drag and drop it to the desired position. An orange feedback will guide you when placing the column between other columns.
It took me a lot of time and effort, to get it working. The drag and drop idea is cool but the interaction is not right. I was selecting all, and click again to do the drag and drop. However I notice, I need to do this using a single click.
