How can I keep commas from delimiting my data?
How can I use the data + or data - function to move data between two menus if I have a comma in my data? Example, right now I can move "John Doe" from Menu 1 to Menu 2 without a problem. If I write the name out as "John, Doe" with a comma, then when I trigger the Data+/- function, it breaks out John and Doe into two separate lines.
How can I keep my data from separating and still use a comma in my menu?
Hi Jesse,
Your request has been answered through our Customer Support Portal.
Unfortunately you won't be able to keep commas and you will need to use any other sign.
Sorry for the inconvenience.
