This is a little tricky because the Date widget doesn't contain Day names. You could try populating a Data Master with the days and date of the month, and then creating an "On Page Load" + "Set Value" event for the text field that will display the Day name. For the value, create an expression that filters the Data Master according to the date, and then selects the Day name associated with that date. Unfortunately this is difficult to test out since you'd only be able to try it once each day (unless you change your system date).
Hope this is helpful - let me know if you'd like clarification on anything.
This feature has been added in the newest version of Justinmind.
