How to repeat actions?
Solved Dulai 6 years ago
so I have created a dynamic panel, where some planes are moving from A to B. I am looking for a action, where I can set a repeat so I don't have to create further planes. That means if the 5 planes, which I have already created are done moving, the panel should start repeating doing the same movement.
Is there a possibilty to create such kind of function?
Thanks in advance.
Sure, you can use a variable and the 'on variable change' type of event. The same idea is used in this tutorial https://www.justinmind.com/support/designing-a-countdown-timer/
