Make sure you're dragging the text widget correctly into the dynamic panel. You can check this by looking to the outline panel, and see if the text widget is in panel 2, and isn't on top of the dynamic panel.
If you're not sure, if possible, attach a screenshot of your outline panel.
Hi Mark,
The issue is that you need to create a 'set active panel' event instead of a show/hide event. Create an 'on click -> set active panel' event for the 'manage user' text, and have it set 'panel 2' as active.
Hope this helps.
Hi Mark,
Hi Mark,
Hi Mark,
It is inside the panel2
result
result
The vp file is available at
http://coolshare.com/temp/netelastic_ui_1.vp
Hi Mark,
Hope this helps.
Hi Mark,
Hope this helps.
Cool! It worked
Cool! It worked
Another question: how can I place checkbox in the first column of a table so that we can select a row in the table?
Which table should I use?
thanks
thanks
