Html website,(folder) not showing correctly on the device on my project
In Progress Anton Bernar 6 years ago
i am testing the justinmind, and lovin it, but testing if it would have all tools that i need, creating a project i got stuck on an error that i can not solve...
i am sending two projects atached, in one of this two i just have 1 button and the website, this one was created for testing purposes, to see if the problem was in justinmind, my project or the website itself but this works as it should on the mobile device, it opens ok!
in the other one, when you click on the third button the same website dos not work as it should on mobile devices, just works at the simulate browser... at some time in the beginning it was working, but now, even deleting and adding again wont make it work...
How to solve this? thanks!
The files are bigger than what i can attach, so i am sending inside this link
https://we.tl/t-JyhveC5N8w
thanks!
Replies (8)
We tested the prototypes and they seem to work correctly. What kind of mobile device are you testing the prototypes on?
Tablet Samsung T-285M
Are you using the view on device mobile app to view the prototype on the tablet, or are you viewing it some other way?
i click on "view on device" in the software first and then, using the app, click in "view on device" option
here is two videos, showing how it appears
https://www.youtube.com/watch?v=BbOr5I8CGWg&feature=youtu.be
https://www.youtube.com/watch?v=y4NQJkAcAvk
thanks
Any news about this? thanks!
Im still waiting some fix for this
We found a problem with the ‘Show’ action if the website is hidden by default. It seems that the website needs a refresh after performing the 'Show' action. We'll work on fixing this, but in the meantime, we found a workaround with by executing a 'Resize' action, which refreshes the website contents (check “1_hidden_workaround.vp”).
Find the edited prototype here: https://we.tl/t-i9sKvCBMEc
Greatttt!!! I will test, thanks! Really apreciated!
