Hello, I wanted to use hide and show functionality, but I am not able to see these options. I have 9.2.0 version. Can you please tell me how to access it? I am using the free version currently.
Yes, I can only see the hidden simulation, which is the second image. And If this makes components hide and show, then could you also tell me the process to do it.
For the Layers palette, are you selecting an Element and then trying to hide it using the feature in the Layers palette? Can you attach a screenshot of what you are seeing?
I was referring to this youtube link for creating a popup, but under the properties section, I can not see the hide/show option directly if I select the rectangle.
Thank you for your response.
Are you able to see either of these two hide/show features in Justinmind?
Or
Let me know if either of these two options show up.
Or
The "Hide Component" button that that video is referring to was replaced by the Eye button in the Properties palette (see photo):
So if you want to recreate what was created in that video, you can replace the "Hide Component" with that button instead and it should work.
Does this help answer your question?
